removing keel
2
- - corpus christi
One of my keel bolts is broken and the keel appears to be dangeling.I have a 1984 22'hunter.My question is I can't locate where the forward bolt is or how to access it.any info would be apprieciated.Thanks.
Apr 3, 2006
4
- - Stockton Springs, ME
fix it before you loose it
You need to remove the balast weights under the table to gain access to the bolts. Make sure that you are on the hard as water will quickly start coming in through the holes. You will also want to block up the keel so that it does not fall unexpectantly. You should go ahead and remove all of the bolts and inspect the pivot pin and bushings while you are at it. The shaft on mine was bent and the bushings were quite worn.
May 18, 2006
2
- - corpus christi
ThanksBOB
Boats on a trailer at a yard that says it will take 3-4 thousand to fix keel.I'm going to pick up tomorrow and attempt to fix myself.I can't find any info that shows or tells me how to do it so I'll figure it out as I go thanks for thr info.
