G
greg
I have a used 1979 swing keel cat 22. I want to remove the keel and check the keel bolt and any bushings. I understand it weighs about 500 lbs. It now sits on a trailer. Is there any technique I can use to remove the keel while still on the trailer? Or will it be necessary to lift the boat off the trailer? It appears that there are 4 bolts at the bottom of the hull that hold the keel pivot to the boat. Aside from the keel locking bolt, and winch attachment are there any other bolts? Any helpful hint or ideas would be appreciated.
