Thanks alot guys, really appreciate all the advice. Nemosuit, what you said helped alot, its advice like that, that I was hoping to get. Looks like I`ll have to rethink the plastic part for a keel. Now I`m thinking maybe a flat piece of steel , and shape the plastic so it fits snuggly in the groove flush with the bottom of the boat. Cut a dado the lenght of the plastic and mount it to the top edge of the flat steel so the steel hangs down about 6 - 8 inches below the hull. Mount this where the old keel was , making it weight around 150lbs. This should address the lateral resistance needed for steering and also help with stability. What do most of you think of 150lbs as far as being suitable for keel weight. Remember the mast and all rigging is already off the boat
Like I said, I don't know much about sailboats, but I have had some experience with nautical design in other types of vessels. I can tell you that a 2'X4' piece of 1/2" steel weighs about 160 lbs.; less if you trim it.
That's going to be about 100 lbs negatively buoyant in seawater, but again without the exact W&B specs for the boat, it's impossible to accurately calculate the resultant change in stability.
It's night time, so I'm not going down to measure my keel right now; will try to do that tomorrow. Then I can tell you what it's weight versus potential buoyancy is.
What seems important to me at this point is: The boat comes with a long, heavy keel that hangs down below the boat; so, the moment-arm of that station is a goodly distance down below the boot stripe. Your design sounds like it wants to eliminate that significant stability factor, and replace it with something that's going to be lighter, and at less of a moment-arm from the waterline. It looks like that's going to greatly reduce the boats positive dynamic stability: the tendency to return to a normal attitude when displaced therefrom.
Then again, I've got to remember: the keel was designed to offset the considerable forces induced by the sail and rigging. You're talking about eliminating the sail entirely. That's got to be points in your favor, stability-wise.
Now, it starts to get beyond me. I don't feel capable of calculating what the forces generated by the sails, et al, might be; or how much the lack thereof might contribute to the stability of a boat with the keel modified as you suggest.
It's a lot more complex than it looked at first glance.
If I had to guess (and that's all it is, an uneducated guess) I'd think if you had that 160 pound keel tucked up inside the keel trunk or hanging slightly below (or maybe one that was made out of two layers of 1/2", so let's say 320 lbs, more or less due to trimming) and there isn't a sail trying to tip you over that the keel has to resist, your idea might have a fair chance of working.
But again, this is just how it seems to me off the top of my head, and without any real math (boat stability specs) to work with.
When I get my Mac22 into the water, the first thing I'm going to do (after I check for leaks) is take it for a short drive without the rigging, on the outboard motor alone. I have a motorized keel winch which brings the iron fin up and down pretty quickly; and I might try running on the motor with the keel up, just to see what happens. I can let you know how that works, for what it's worth. But again, it won't be for a while yet.
Wish I could be more certain, but right now that's the best I've got.
VBR,
Pat
