I would like to remove the crank cover board and cut and finish a new one. The crank however needs to be removed. I'm not sure how to remove it. Should I put a vice grip on the center thingy and turn the handle clockwise or CCW or is there another way? Also, the screw in the top right part of the pic has stripped out of the fiberglass. Once I get the board off should I feed slow 2 part epoxy into the hole and re drill so the screw will stay in? Any thoughts? Thanks for any help.
