Removing engine for repair
anewth
Apr 21, 2005
14
Hi all,
I have a problem with my engine - the exhhast elbow had a small hole in it and has sprayed salt water and caused the some corrosion on the engine and gearbox casing.
So at the end of the season I will need to remove the engine and take it home for refurbishment.
The yard that I keep my boat at in the the winter (on the hard) has limited cranage so I was wondering if anyone has removed their engine by using the boom as a crane. My idea is to lift the engine out using a block and tackle on the boom and swing it over the side and down to the ground. The engine and gearbox weigh about 90 kilos.
Does this seem feasible to do while the boat is sitting in its cradle?
Cheers Ade.
Nov 8, 2001
1,818
Hi ade
More than feasible. I have done this removing the Volvo MD6A which weighs a damm sight more than 90 kg!
Cheers
Steve B
Oct 30, 2019
1,459
The situation shows the importance of visually inspecting the engine while it is operating, with a flashlight and inspection mirror (hearing protection too). Oil, fuel, coolant, raw water and exhaust are all present under pressure in an operating engine, and giving the running engine close scrutiny will often reveal a leak while it is still quite minor.
Nicholas H. Walsh P.A.
111 Commercial St.
Portland ME 04101
207/772-2191
Fax 207/774-3940
This email is from a law firm and may contain information
that is privileged or confidential. If you suspect
you were not intended to receive this email,
please delete it and contact us.
Sent: Monday, August 22, 2011 9:39 AM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] Removing engine for repair
Hi all,
Cheers Ade.
Oct 30, 2019
1,459
I've used a backhoe, but my mast was down, so I didn't have the mast/boom option.
I've used the boom option on a similar sized boat/engine where I helped to get the old one out into a cart on the dock. We put an extra halyard down to the point on the boom where the engine hung from, just to be sure it was secure.
I'd double up on your lines and make sure the boat stands are secure, as you're swinging the weight out over one side.
As Steve said, "More than feasible." Just take your time and have some help standing by.
Peter
#1331 'Sin Tacha'
Oct 31, 2019
230
That's standing by . . . not under!
From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On
Behalf Of Peter
Sent: August 22, 2011 12:05 PM
Subject: [AlbinVega] Re: Removing engine for repair
mast/boom option.
sure it was secure.
help standing by.
Peter
#1331 'Sin Tacha'
anewth
Apr 21, 2005
14
Many thanks for all of your replies.
Nico has a very good point and had I taken his advice I wouldn't be in this position of having to take the engine out at the end of the season. Oh well - live and learn!
Cheers,
Ade
