Dean Strong
Peggy,I'm rerouting my MSD plumbing, and want to eliminate the head direct discharge sea-cock and thru hull. I can already empty the holding tank via a macerator and thru-hull that has been added. The direct discharge is never used--it's old, and starting to corrode too. If I eliminate the direct discharge sea-cock, I'll have room to add a larger tank because it just happens to be positioned against the holding tank wall.I saw the earlier discussion this month, but it doesn't solve my problem of the sea-cock being in the way of a larger tank.Can I remove the sea cock, and cap the the thru-hull in some way, and if so, how high will this protrude above the inside of the hull?Thanks,Dean Strong"Synchrony"1990 Hunter 30
