Michael
I contacted 3M about removing 5200. Thought it might help others too.Thank you for contacting 3M Marine and Specialty Vehicle Department.If the adhesive sealant is:UNCUREDClean surfaces with 3M General Purpose Adhesive Cleaner (part number#08984) or acetone. DO NOT use alcohol-containing solvents, which willinhibit the cure of the sealant.CUREDPolyurethane adhesive sealant must be removed mechanically if cured. Use aknife, razor blade, piano wire, putty knife or sandpaper.Heating to remove 5200 and 4200 is not recommended because of the vaporsgiven off and possible damage to the substrate.5200 is meant for permanent applications. If removability is important inyour application and you still need adhesive qualities use 3M MarineAdhesive Sealant Fast Cure 4200. Think of 4200 as being the same as 5200but it is half the strength of 5200 and you would have removability.If you only require sealant qualities in your application, then use the 3MMarine Sealant Fast Cure 4000UV.
