REMOVE
RAYMOND KELLY
WHAT IS A EASY WAY TO REMOVE VHF WIRE INSIDE OF THE MAST ON A ODAY 25'?? I REMOVE THE TOP HEAD OF THE MAST BUT COULD NOT GET IT TO MOVE EITHER WAY. ARE THEY TIED INTERIALLY?? ANY SUGGESTION??? I DO NEED A NEW VHF WIRE INSIDE OF THE MAST. LOOKS LIKE ITS THE ORGINAL VHF WIRE. LOTS OF DAMAGE FROM HURRICANE CHARLEY AROUND HERE. R/K
bruce cornell
mast rewire
if coax is tied in, you might consider all new wire, pull the whole thing out one end while a friend feeds fresh wire/coax in from the other. if not, electricians have a coiled wire they feed behind walls etc to feed wires, borrow one of these, run it up mast and attach new coax to end and pull thru. if coax is bad, would recomend all new wires in the mastat same time...
