Remove Stove Top?
Apr 24, 2020
111
Hunter Cheribini 37 South Portland
I have an older Force 10 stove (FT635 PR) with a warped top. I'd like to remove the top and bend it flat. I can't figure out how to remove the burners from the stove top. Help?
Apr 24, 2020
111
Got the link but mine doesn't have 2 screws on top and I can't figure out how it's supposed to be removed from the top plate.
capta
Jun 4, 2009
5,008
I learned many years ago that, "if it ain't broke, don't fix it."
I was changing the oil on my old Kubota diesel and thought how nice it would be to put an air cleaner over the open air intake. After considerable effort I installed a nylon stocking over it and it seemed really tight. Not so much. Turned the engine on and it sucked that nylon stocking into the valves and I had to spend a couple of days cleaning up my mess, and without a new head gasket to boot.
Feb 19, 2023
102
Dufour Dufour 34 Clipper Yacht Harbor
Hard to tell which one you have. I googled it but no luck.
Do you have a sticker, plate , more images ?
I'd find the blowup, that helped me take my oven apart to pieces to replace the thermocoupler.
Example of what I used.
