So today I had the (keel stepped) mast pulled on my C36. This was in preparation for removing the bulkhead. One problem I ran into: The plate that the mast sits on is made of cast iron (I think). Anyway, there are four bolts holding this plate down. These screws have corroded so badly that they all broke off when I tried to unscrew them. What's worse is that they seem to be frozen, bonded, to the plate itself inside the holes. At least I think that's the problem In any case, I can't pry this plate up off of them. (I'm assuming that the plate isn't fixed to the boat in some what that I can't see.)
I've sprayed PB Blaster onto them and I'm hoping that after it works its way down that this will loosen up, but if it doesn't, what suggestions do you have? Should I try heating the plate up? If so, use a heat gun or a propane torch? Any other suggestions?
Thanks.
(NOTE: This plate sits up high enough that I can't get the new bulkhead in. I just cut some off the bottom of the old one to slide it out, but obviously I don't want to be doing that with the new one.)
Thanks.
