Removal of varnish from gelcoat
166
Nonsuch Ultra 30 Gulfport, FL
The PO did a very nice job of varnishing the brightwork with Petit Captain. About 6 coats worth. The only problem is that he did not use masking tape and he slopped it all over the surrounding gelcoat. I would appeciate any ideas/ advice about the best way to remove the excess varnish without damaging the varnish on the teak
May 5, 2006
1,140
Knutson K-35 Yawl Bellingham
Laquer thinner. If applying varnish and YOU slop it on the glass, use Denatured Alcohol.
Jun 6, 2006
6,990
Your hunting knife. Use the tip and scrap gently like you where peeling an orange rind. It will just flake off once you get underneath it. Then use a 3M scratch pad to smooth out any scrapes.
Hunter 25_73-83 NORTH POINT MARINA/WINTHROP HA IL
Go to Scraperite.com. It is a plastic razor blade that will not scratch your gelcoat. But, be careful as it is as sharp as a metal blade. Good luck and good sailing, Ron
Sep 29, 2008
1,936
Catalina 310 #185 Quantico
West Marine has these
2nd this. West Marina has them for about $5-6. Very useful.
Jun 9, 2008
1,792
- -- -Bayfield
Both Pettit and Interlux have paint and varnish removers formulated for gel coat. Do not use the Zip Strip and others found in hardware stores as they are too aggressive for gelcoat.
