1st I have a 2001 H260 with mercury 9.9 bigfoot outboard motor. Installed is a Panel the houses the tack, fuel gauge, hour gauge and the key start. the problem is ... I turned the key and nothing happens... there is power to the start solenoid and a good ground. I made sure it was in neutral in case there is a neutral switch (although I don't think there is) I went through all the wiring and traced power and I don't think I am getting power to the coil with key. I can't figure out why it wont work. The motor started just fine 2 weeks ago with the only issue that I was unable to turn it off. I did find a bad connector that may have been that problem... but I now think I may need a new key box... (I haven't pulled it out yet) .. how can I find out what the make and model that was installed in the boat... I have the docs for the remote control harness kit but nothing for the key box it self, Is that a Mercury part or Hunter?
