After much-too-much time on my garage floor, I finally completed the cut-down and transformation of a too large second hand sail into the perfect (in my dreams!) loose footed main sail for my boat. I installed it today. But because of heavy winds today, I did not give it a real life try. The block and tackle arrangement I have set up gives 15:1 purchase. Allowing for friction losses, a 50lb pull on the control end might result in (say) a real life 10:1 =500lbs of tension along the foot.
First question is: Can I leave the foot fully tensioned between outings? Or is it better practice to release the tension when the boat is at berth?
Second question is: Please suggest websites that give instructions on outhaul tension adjustments vis-à-vis wind velocity, luff tension, etc? My only previous experience is with main sails with slugs attaching the foot to the boom. Due to friction of the slugs, I tended to just give the foot a moderate bit of tension ... and then forget.
