I have a friend that has intermittent glow plug problems with his Volvo MD 2030. I traced the issue to a loose fitting relay in the socket. The relay has metal tabs that fit into female connectors inserted in the plastic base. Basically, it's a spayed (sp?) connector. The relay is about 1 cu in in size. I think over the years with vibration, the female part has spread the compression tangs and electrical connection suffers. The relays are contained in a housing so they are pretty clean and I have cleaned with appropriate cleaner. There are two relays one for the glow plugs and one for a starter relay. The glow plug relay is definately looser than the other. I hope I've explained this sufficiently. So, my question is can the individual wires be removed from the plastic base and be reinserted after some adjustments? In the long term these type of devices should be moved off engine..
