I pulled the rub rail on our M26S to retighten the deck/hull bolts. Most were barely "finger tight". The biggest job was removing enough sealant from the bolts and nut to get a socket on them! I also forced 5200 into the edge of the joint as there were many gaps. Anyway, it's now time to reinstall the rail - and I have a few questions...I assume I need to dab sealant on the bolt heads and nuts - I'm thinking 3M 4200 as it'll allow the rail to be removed again?Also, should I snap the rail on immediately after applying the sealant - or let it cure first? ThanksChris
