C
Chip Willis
past recall replacement on our C-30 1983. My mechanic informed me of this when I had asked him to perform some other maintenance on the engine as well as look at the click-at-startup problem I was experiencing. He said that 8 out of 10 C-30’s have had this conversion done and he could do it for $175.00. Here’s some history: I’ve had this click-at-startup problem and a no-start problem since owning the boat (almost 2 years now). I already re-wired the ends of the harness connectors and replaced the glow plug switch but it still happens once in a while. (I am considering checking the ignition switch next.) I even had the mechanic check it out at the beginning which he thought was a loose terminal end so fixed that. (Interesting that he didn’t mention the recall at that time??)The replacement includes replacing the amp-meter gauge with a voltage gauge. I’m told that the way the wiring is set up now the charging goes through the gauge and so it is dangerous and loses some of the effectiveness. I seem to recall reading about this someplace, some time ago. I was also told that it is a fire hazard as the wires in the harness are old and deteriorated and could cause a fire, again so I am told. I am concerned about the fire hazard. I do trust the mechanic which I had asked to check out a clicking start up problem I have had periodically. He did try to fix the clicking once and said he thought it was a loose terminal end and he fixed it. This was not the case as it still happens time to time. My questions are these:•How can I tell if the wiring has not been replaced and or if this work needs to be done? •Is this something I can do my self with limited wiring knowledge? •I do not mind learning by doing, but are there tricks to this or is it straight forward?•What tools would I need?
