Refrigerator front door gasket
gsg900
May 1, 2019
4
Hunter 420 Stamford, CT
Been working through the known issues in my (new to me) 99 420.
Front door for the grunert obviously has been leaking. Was obvious the first time I walked on - I'm ready to tackle it and have searched the forums but found little in the last few years in terms of a proper gasket?
Also looks like I'll need to adjust the door a bit - can't believe the leak made it warp as only the front is wood. Any advice on re-seating the actual door? I plan to pull it when I replace the gasket.
Did the dollar bill test and it obviously failed. The fridge is running fine but this is causing it to run longer than I'd like.
Thanks for any advice, part #s, etc. Great to have this forum here.
-Gabe
senang
Oct 21, 2009
316
hunter 38 Monaco
Find a local shop manufacturing rubber products. I have one close by and never thought they would do fridge gaskets, but they do gaskets on demand in the dimensions the customer asks for. Just be damned sure about your measurements.
