also posted in Catalina 310 forum
In my 2001 Catalina 310, there is a small white tube that drains water from the refrigerator to the bilge. Is this the proper place to drain?
It keeps the bilge pump going amost all the time, because the float switch will engage the pump and when it shuts off, a great deal of water flows backward into the bilge and this keeps cycling. Finally last night I sponged out the bilge so I could get some sleep. I did manually run the pump until it was sucking air and I let it run a bit longer than normal. That seemed to keep the water from coming back in the bilge somewhat.
Will the pump continue to pump air if I let it run?
Will the pump burn up?
How bad is all this work on the bilge pump?
Should I be concerned about a fire?
