Refrigerator conversion
Oday 35 and Mariner 2+2 Alexandria, VA
Florida sail said:
To clarify things: The boat that I am looking at is a Nonsuch Ultra, built by Hinterhoeller Yachts in Canada and does not have refrigeration. Adding insulation will probably be a must regardless. The Norcold conversion unit appears to be a possibility and if I want to spend significantly more $$ the Frigiboat conversion would be my choice. Oh well, decisions decisions.
I have the norcold conversion. Works like a champ. I recently added foil wrapped fiberglass insulation to the outside and what a difference it makes. Less frost, more cold, less run time. Plus the AC/DC switching is awesome. Dock power keeps it cold and reduces battery drain. I can run nearly 30 hours with it and my GPS/stereo/VHF/autopilot and not have to run the motor. Though I have gotten through an 8 day cruise off shore and ran the engine for about 2 hours a day, kept the batteries from going below 50%.
Sep 28, 2008
922
Canadian Sailcraft CS27 Victoria B.C.
Charging with the engine 80% is the practical limit as the last 20% can take 6 to 8 hours as the battery resistance rises and the acceptance drops. If you are motoring a long distance you will eventually get to 100%. If you are cruising away from shorepower for long periods either solar or wind will take care of the last 20% without engine wear, fuel consumption, increased engine maintenance and listening to the engine all day.
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
You are 100% correct, that was what i meant to convey, but failed to explain clearly enough...
