Chris, Gary...
Chris, if your aren't happy (and it doesn't sound like you should be) make them get another mechanic -  don't give up on this - it's too important.Gary, Hunter is notorious for underinsulating the boxes on it's boats.  I have *no* idea why they do this, since insulation is relatively cheap.  On my H45, I got fed up and drilled some 1/2 holes in the furniture, sprayed in 2 part foam, and plugged the holes with teaks plugs.  It really helped my running time a lot, although I am still unsatisfied and am considering insulating the inside of the box as well.  If Hunter had done this right to start with, I wouldn't be faced with this problem now.MC
