Refrigeration
C
Chris Glander
I am looking to install refrigeration on my 1984 hunter 34. Would the cu-100 or the coolmatic series 80 be the better choice. Can the super cold machine be used without the watercooling (added later).
Don
Marginal....
Refers are very power hungry. If you put those group 27's together for a house bank and added a starting battery, you could pull it off. With that small alternator, you would be looking at about 5 hours of engine run time per day to replace the power used. A larger alternator and "smart" regulator would cut the engine run time to half of that. This has been my experience with an AB Cold Machine (air cooled) here in FL.
