Refrigeration Temp not regulating
lnikl
Mar 1, 2011
88
Hunter 38 Port Moody, BC
On our recent trip we found that our refrigeration unit would not cycle to keep the temperature "right". It ran continuously even though I had turned it down all the way, including trying the "stop" setting. Not looking for sympathy but all my beer was frozen solid :cry:
The refrigeration unit is an Adler Barbour on a 1983 Hunter 34. Presumably it is the original that came with the boat. Clearly, it continues to work well -- too well.
Is this likely to be a simple problem of a malfunctioning thermostat control (presumably a fairly easy swap for new) or is there something more complicated that I should be concerned about. I would appreciate hearing any experience you may have.
Nov 6, 2006
10,117
Sounds like a bad thermostat or a short in the wires between the thermostat and the control unit. Since thermostat is a simple "on/off" you can troubleshoot it by (power off first) removing the wires at the control box and noting the resistance as someone turns the knob from off/full hot to full cold.. Should be open at first then click to a short with a little rotation of the knob. Look carefully at the connectors to be sure that there is no short at the control unit. Thermostats do fail. but not really that often.
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
I wouldn't as that just adds complexity.
Don, I'm not sure why you would think that. They are both just thermostats. I intend to replace my mechanical thermostat with one of the electronic ones I referenced. At $18 I think it is a great solution.
I replaced my mechanical one with another mechanical one just after we bought our boat ($68). After a couple of weeks of adjusting it cycles the fridge temperature between 32* and 40*. I complained to the vendor where I purchased it because of the excessive hysteresis. He explained these mechanical controls are designed to measure temperature of a metal plate, not the air temperature as they used in our fridge using a spill over fan. He said it was working as designed. It was a shop that specialized in repairs to boat refrigeration systems in Miami, so I believed his explanation.
I think this electronic unit is a big improvement over the original equipment and only about 1/3 the cost. The set up and adjustment should be easier and faster with a digital readout of the set temperature. Several sailors on this forum have installed them and as far as I know are quite happy with the improvement.
Regards, Bob
Jan 12, 2011
930
Hunter 410 full time cruiser
Regards, Bob
I have considered one in the past. But I don't know what "improvement" one could be, it is just a thermostat. The mechanical regular version is a nice basic thing and I don't see how replacing it with something more complex is an improvement. I read on an expert site when he considers it a one of the big mistakes installing a electronic unit.
So, set it and forget it!
