Pete Loewenstein
I have factory installed refridgeration on our new H356, and think there is a problem with the spill-over fan that moves cold air from the freezer section into the refridgerator section. I don't feel any air movement or hear any sound coming from the spill-over fan, even when I crank the 'fridge control knob wide open. I left the control set on "6" for a three-day period, with the same setting on the freezer control, and was only able to get the 'fridge temperature down to about 55 degrees. When the boat was first delivered a couple of months ago, I could feel air movement from the fan. Now I don't. I don't know if I just happen to check the fan when it is in the "off" portion of a cycle, or if I should be able to force the fan into operation by cranking the control knob to its highest setting. Any advice is appreciated!PeteS/V "Sh'boom" (H356 #53)
