Went to the boat this weekend and found the A-B Super Cold Machine not making super cold. Plate was warm and the fan/compressor were cycling on and off. Went to the anolog amp meter and and observed that about 30 seconds after the fan started the amp draw would spike up about 10 amps then over the next few seconds would creep up another amp or two then abruptly drop back to baseline. Manual say expect about 7 amp draw. Confirmed it was the compressor cycling on and also noted a single flash pattern from the diagnostic led. This is supposed to indicate low voltage. The voltage regulater for the solar panels is indicating 14.03 volts at batteries and the charger is on (440 amp/hr bank of 6 volt batts). My meter shows 13.9v where the 8g wires enter the Alder-Barbour unit. I watched the voltage as the fan kicked on and saw about a 0.4 volt drop but when the compressor kicked on the voltage went to 5.9 then the compressor cuts out. The unit is about 6 yrs old. What is going on here?
