I have a clogged refer drain and can't seem to figure out where or how the drain line runs. I tried liquid drain cleaners and a 1/4" eel will not make the 90 degree bend at the drain hole. Any ideas????
I would not use a caustic cleaner on the refer drain the hose hunter uses may not be able to handle the chemicals.
I have used warm water with dawn dish soap to get the usual crud out of the hose.
later Mike
