refrig./freezer
2
Just purchased a 2003 361 the refrig. and freezer do not cool. They seem to be running and air is circulating but nothing is cooling. The breaker is on the thermostat has been adjusted. Is there something else I am missing? Another switch? Do they both run off the same compressor?
2
Just purchased a 2003 361 and the refridg. and freezer do not cool but seem to be running. Help. Am I missing something.
Rick I
Jan 6, 2007
414
CS36Merlin and Beneteau 393 - Toronto
Might be a refrigerant problem. If the set-up is a small front load fridge and a box freezer, they both run on the same compressor and the fridge is cooled with a spillover fan from the freezer. You need a set of guages to test the refrigerant.
