Can anyone tell me what the difference is between the Refridgerator Switch on the breaker panel and the Seawater Control switch on the wall is?
I understand one is a water pump. But are you supposed to put both switches on at the same time? The switch alone on the panel will cool both the freezer and refridgerator. Should the water pump be on to keep it from overheating?
