I want to do the following to my 1979 Hunter 25 for coastal cruising. Redo the entire electrical Install two 50wt solar panels,Install USCG Water Treament System Install a through-hull for treamentInstall Dodger and BiminiPaint the hull and bottom paintNew standing & running riggingMove fresh water tank to V-berthWhat order do you think I should do them in? Currently it's in a slip, however should I do all the work on the hard? First project boat and want to go about it the right way.
