We are glad to report that Whisper, Vega #2751, has found a new home with us in the
Chesapeake Bay. The previous owner, Ron Bodkin, was active on this forum, and we've
been taking advantage of this excellent resource in making our decision about buying the
boat. I have a feeling that we'll be fairly active here as well as we get ready to take
Whisper over the horizon next year.
Now the work begins, however. We are refitting Whisper for a 2-3 year cruise in the
Caribbean, and possibly beyond. Our aim is for a departure date of November, 2006. As
such we have a few questions and concerns:
1) We are replacing all standing rigging. The existing rigging is 3/16 inch wire with
swaged aircraft eye terminals (pin size is 5/16). One rigger we spoke with suggested
increasing the size of the upper shrouds, as well as the backstay and forestay to 7/32 inch
wire, and drilling out the tangs to accomodate 7/16 inch pins. After reading the postings
here regarding wire size it sounds like there is a consesus that 3/16 wire and 5/16 pins
are sufficient. We would appreciate a confirmation of this assessment, though.
2) We plan on using swaged aircraft eye terminals for the upper ends of the stays and
shrouds, and use Sta-loc fittings for the bottom end. Does anyone take issue with this?
3) Whisper has a Proctor mast with cylindrical spreaders. The rigger we are using seems
to think that the spreaders aren't aligned properly, i.e aren't bisecting the angle of the
upper shrouds (currently they are angled up at a slight angle, but I don't know exactly
what it is). Does anyone know what the mast-spreader angle should be on this particular
mast?
4) We are also replacing the genoa sheet winches with either Anderson 28ST or Anderson
40ST winches or Harken 32ST winches. The question I have is wheather there will be
space for the nuts and bolts for these winches. The base diameter of the 28ST is 125mm,
and the 40ST has a base diameter of 152 mm, while the Harken is 139mm. I'm not sure
how far inside the base diameter the boltholes are. Has anyone installed these types of
winches on a Vega before?
5) Sails... We are replacing the original main and 135% genny with a new main and
probably a 100% jib from North Sails, thinking that in the Caribbean the winds will be a
steady 15-20 kt. What would be your choice of working jib/genny/yankee (?) size for
Caribbean cruising, with comfort, speed and balance in mind?
6) Traveller... is there any point in replacing the original captive track non-roller bearing
traveller with a new one? Do you find that you use your traveller to balance your Vega?
7) Windlass.. we are considering buying a manual windlass (probably a Lofrans) to handle
our ground tackle. Any tips?
We could probably go on and on, but we will leave it at this for now. Thanks in advance
for any advice!
Hans Ericsson & Kristen Miller, s/v Whisper
mast?
for any advice!
