I need to sand down and re-finish the sole of my boat. The problem is that every 2.75" there is a recessed rubber strip for slip prevention. Has anyone any experince with how best to get the job done?
sanding of the sole is not necessary. Scuff the sole with a 3M pad and refinish. You will be amazed with the result.Should you have deep scratches, use a course (black) 3M pad and remove most of the finish until the scratches have been feathered and then apply a new coat of varnish.Jim
