Refinish for Cabin Sole
Nov 13, 2010
11
Hunter Passage 42 New Orleans
We're thinking of refinishing the cabin sole on our 1992 HP42 while we're in Grenada (or Trinidad). Anyone have any thoughts or tips on this project?
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
dont use water based finishes i did this and wish like hell i had not done this ...in my infinite wisdom i had it in my mind that it would be a good product to test and used and now that i have done the test i can see that i need to stick with what i knew to be a good finish ...man don't ya just hate it when a plan does not come together ....from now on i will stick with oil based finish
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
Many posts on this subject with many opinions. I used polyurathane on my old boat. After sanding old material off I used about 6-8 coats. Started with thinned coats and gradually less thinner in the later coats. Sand between coats and make sure no dust before coating. Use whatever gloss type you want from satin to high gloss. Caution, be careful sanding not to go through the thin veneer.
I plan to do my current boat once the dog is gone.
Aug 25, 2010
30
Hunter 376 Charlestown, MA
I spent 15 years in the chemical industry supplying waterborne resins to polyurethane suppliers. W/B PUR technology has come a long way, and I have used with great success on floors at home.the marine environment is very tough as we all know. I chose a solvent based approach when refinishing the sole on our 1998 H376. I have been very pleased with Daly's Profin oil-modified urethane on my cabin sole. (The original OEM finish). Dayly's is a great company to work with. I pulled the sole, sanded down and applied 4-5 coats. Easy application with foam brush, and a beautiful finish that has worn well.
Jul 26, 2009
291
Put this down about 4 years ago (brushed on, not the spray). Has held up very well, a little slippery when wet but other than that, no complaints.
Nov 13, 2010
11
Thanks all. But I obviously phrased the question wrong. What I wanted to know -
whether anyone had information on having this done in Grenada or Trinidad?
