Refill compass?
pupluv
Nov 11, 2007
90
- - wilmington, ca
I have a
X-10-M Ritchie Sport Compass
that I inherited. However, there's no fluid to cushion the movement so it's almost useless on a sailboat. Has anyone ever re-filled a compass?
I imagine I could drill small holes, fill it, then plug them up. What would be the right fluid? rubbing alcohol? vodka?
7,332
Alden 50 Sarasota, Florida
Every Richie compass with which I am familiar has a fill hole. As to what fluid to use, not all mineral oil is equivalent to compass oil.
More important, refilling it without first figuring out why and from where it leaked out is a futile exercise. If it's old and needs a new diaphragm requiring expertise to repair properly, it is nothing more than a pretty paper weight.
May 24, 2004
7,153
CC 30 South Florida
Refilling an old compass is not a do it yourself job. Most likely the seals are dry and deteriorated and casings have been deformed. An authorized manufacturers repair shop will probably replace 90% of the components fill it up and pressure test it for 3-4 days. For a little more you can buy a new one of the shelf. Years ago I got Ritchie to sell me a gasket set and the glass sphere and a bottle of compass oil. It was work and money down the drain. Within a week it had a quarter size bubble and within a month it was dry again. The service Rep had warned me so I couldn't blame anyone but me.
Jan11
Apr 9, 2012
45
Ericson 35 Albany
I have a X-10-M Ritchie Sport Compass that I inherited. However, there's no fluid to cushion the movement so it's almost useless on a sailboat.
It's a throw away... $25 at Amazon.
May 24, 2004
7,153
CC 30 South Florida
Oh, I was talking about a larger compass, that is a clear throwaway as I doubt parts or service would be available. To answer your question you may use mineral oil found at any pharmacy.
Feb 2, 2006
470
Hunter Legend 35 Kingston
Just filled my Ritchie compass. It had formed an air bubble over the winter.
Use Mineral Spirits and NOT Mineral Oil (for Ritchie compasses at least).
Very simple to do for their larger compasses. There is a fill hole with a
screw in it. I used a syringe to fill it up to avoid spilling. Simply orient the
compass so the fill hole is "up", and remove screw. Fill slowly, and gently
burp our remaining air bubbles until there are none left (can be hard to
get ride of the last tiny bubble(s)). put screw back in fill hole.
My outstanding question is why I lost fluid this winter and not before. Maybe
a seal is failing? My fill hole screw was not terribly tight so that could have been
it.
Chris
Nov 6, 2006
10,041
A couple of compass manufacturers use an isoparaffin that has been hydrotreated and scrubbed so that it is very clear and has no impurities that might turn yellow in sunlight. We made it at the refinery where I worked; its brand name is Isopar M. It is kerosene that is purified. Similar to "mineral spirits" but with that product, ya may have some yellowing or some attack of the dome after several years in the sun. We made another product that was used as compass fluid; it was "Mineral Seal" oil, a replacement for oil from seals. Again, a highly refined kerosene type oil.
pupluv
Nov 11, 2007
90
- - wilmington, ca
I have a
I contacted Richie who informed me that there are no re-filling holes on this model. I appreciate the advice to toss it and buy a new one, but I hate to throw things away for an apparently fixable problem
So I'll drill the case, insert mineral oil with a hypodermic and seal her up. I'll let you know how it goes. Cheers
Nov 23, 2011
2,023
MacGregor 26D London Ontario Canada
Timely thread.
I noticed the other day that the compass one one of my boats was half full! It's the "make a big hole" in the cabin type too. I think if it lost that much fluid it's time to replace mine.
