reefing
doug
guys, i'm going to "pick your brains".. i'm new to sailing and new to this boat. sailed today, single handed. when it came time to motor into the dock, i wound up the head sail with the furler. let the main sheet out and tried to depower the boat as much as possible. but while i was lowering the main, the boat did two pretty quick 360 degree turns, not a pretty thing. unless you have some suggestions, i'll try lowering the main first next time, then roll up the jib. i think i need some sort of tiller tamer also, had one on my previous boat which would keep the tiller fixed in one position. i've ask another question on a separate thread. thanks for helping. doug
F
Frank Ladd
Definately get a tiller tamer for single handing
Use any method you can to lock the tiller in position so you can work the sails. I usually Backwind the jib and let the main pretty loose with the tiller tied to the lee. This "heave to" position lets the boat drift calmly while I reef or lower sails.
