The "P" and "E" dimensions on my 35.5 are very similar to the V32. The rear line of the 'single line' reef is 15'. The front line that leads to the cockpit is 50'. If I may suggest for the sake of minimizing friction and maximizing sail shape I would use a smaller diameter (1/4") high modulus line like spectra. Also the internal car inside the boom MUST be replaced with a ball bearing double block.
