Reefing Tie Cringles
Other Catalina 30 Tucson, AZ
Oldiesrocker2001 made me think of something. So many times I've seen skippers REALLY SINCH down the reefing ties on their main. This is a mistake. The ties are only used to "tidy up" the sail so it is not falling all over the place. The reefing tie cringles are not designed to take a lot of stress. Check them out the next time your on your boat to see what I mean. What happens when you sinch them down? One result it the sail will rip straight up from the reef tie cringles. Picture that to deal with in a reefing situation!!
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Don
This is yet another good reason to have a loose footed main. Aside from the obvious advantage of being able to adjust the depth better in the lower part of the sail, the reefing tie lines do not need to use the boom to control the extra sail cloth when reefing.
Jul 8, 2004
157
- - Pinedale, WY
Roughs up airfoil
Don: Right On! Even before it tears, overtight reefing ties make vertical creases that mess up the airflow. RK
