Our pulley at the base of the mast is broken. It is used for hauling down the main to the first reef at the clew. I cannot see how to remove this pulley short of cutting it off. I can cut out the pulley and leave the rotating shaft embedded in the mast base. Then replace with a pulley with one where I can push a pin through this shaft hole. Is this the only way?
