I think the roller vs slab reefing debate resembles the outboard vs inboard engine debate. Both systems have their pros and cons. (My personal preferences are: inboard Diesel and slab reefing).
Apart from in-mast or in-boom furling (which isn't reefing), nobody seems to be making roller reefing setups anymore. That should tell you something.
One of the cons of roller reefing is that you loose sail shape, making it harder to beat to windward. A slab reefed main will sail closer to the wind than a roller reefed one ... a great advantage when beating off a lee shore.
When I converted my bagged-out old main to slab reefing I was amazed what a nice flat panel it gave me. Also, it takes less me than 2 minutes to pull in a slab, which encourages earlier reefing. I disagree with some of the points brought up on converting over:
- Adding slab reefing points to an existing sail is not a major job ... a matter of adding reinforcing patches and eyes at the luff and clew points, and adding the hardware and rigging on the boom.
- No recutting of the basic sail shape is necessary.
- The round Vega boom is not a strength issue.
- A bolt rope footed main poses no problems in slab reefing.
- A sliding gooseneck is not a requirement.
I believe that the better speed and safety of slab reefing make it a very worthwhile modification, especially for single-handed sailing.
Peter
#1331 'Sin Tacha'
Peter
#1331 'Sin Tacha'
