Isomat Single Line Reefing System
Neil, you've got yourself a pretty good job ahead of you. I don't know how you can rerun this line without removing the boom.I have schematics from Isomat, but will be out of town until late this week. Isomat has been bought out by Charleston Spars. You might try calling them at Charleston Spars, 5600 Pine Grove Cir., Charlotte, NC 28206. Phone: 704-597-1502I'll do my best to describe the system. I will only talk about one of the reefs. The other is identical. The single line reefing system is actually two lines. The line at the end of the boom ties off to a bale under the boom, leads up an thru a cringle in the sail, back to a sheave at the rear of the boom, into the boom, around a shuttle car (two blocks attached together), and back to the end of the boom. If you look at the back of the fitting at the end of the boom, you will see a couple of lines coming thru holes in the fitting and tied with stopper knots. These are the ends of the reef lines at the back of the boomNow lets talk about the front of the boom. This reefing line starts at the cringle in the sail, where its tied in a stopper knot. It leads down thru a SS eye on the mast about the level of the boom, down to a turning block mounted on the rigid boom vang support on the mast, and back over a sheave in the front of the boom. This line goes into the boom, and AROUND THE SAME SHUTTLE CAR THE REAR REEFING LINE GOES THRU. From their, it comes back out the front of the boom, and leads back to the cockpit thru the turning blocks at the foot of the mast.When the sail is up, this shuttle car is at the back of the boom. As you reef, by pulling on the single reefing line, the line going into the front of the boom pulls the shuttle car forward, pulling the back of the sail down until the rear reefing cringle is on the boom. The forward line also pulls the front of the sail down, since that end of the line goes thru the shuttle car and is attached to the front reef point.Hence, by pulling the one line, you are pulling down both the front and the rear of the sail at the same time.Complicated description. If you still want a line drawing of this, and can't get one from Charleston Spars (Isomat), I can send it to you next week.Your job is going to be figuring out where the line is that slipped back into the boom. If its in just a little ways, you might be able to see it by drilling off the rivet heads that hold the end fitting on, removing that fitting, and looking into the boom. With luck you can reach this line and re-lead it thru the end fitting. If you've pulled the line all the way thru the shuttle car, you will need to remove both end fittings and use something like an electricians tape to re-lead you reef lines.This will all be tedious, but very possible to do with a friend to help. Good luck!
