H216 Reefing
Jeff,Very interesting set of pix. I do my quite differently (accomplishing the same thing of course)! I had never reefed and never seen a boat reefed before I got my H216 so I invented my own way of doing it (I came from the dinghy world and my old Geary and all the other dinghies in my club have no reefing capability).At West Marine I found large SS hooks with an eye loop at the end. Think of a SS eyebolt with the threaded end bent into a hook shape. Diameter is approximately 3/8". I used my vise to form the loop more to my liking. I purchased two of these things.I replace the cleat where you cleat your reefing line (cunningham also) on the starboard side of the mast with a clam cleat. I rigged one of my hooks with a short line. For reefing at the clew end of the main, I hook the hook into the reefing grommet, pass the short line through the clam cleat and cleat it. I have attached the other hook to a longer line and I have run the longer line thru the sheave on the end of the boom, starboard side, forward to another clam cleat. I leave this line w/hook on the boom at all times. When reefing, I put the hook in the grommet on the leech of the main and cleat it down.For gathering the sail up on the foot to get it out of the way using the other smaller grommets, I have attached nylon wire ties to my favorite red bungee loops with the black ball on the end (available at Wal-Mart). The wire tie is simply to help me thread the bungee through the grommet, after which I pull the loop over the ball. I have been looping the bungee around the boom also so it makes the sail look like a closed foot main. I never thought of doing it your way and keeping the main an open foot main!Here were my thoughts:1. For the clew end of the main: I figured inserting the hook and cleating it would be easier and take less time then unthreading the cunningham and re-threading it through the cleat. If I drop my hook with the short line or lose it, I can always fall back and use the cunningham.2. For the tack of the main: If reefing may be in order, I plan on placing the hook in the crinkle before I raise the sail. This way, I only have to tighten it and cleat it off. If I don't plan on reefing, I have no extra garbage hanging on the main and the hook and reefing line are tidy on the boom (I have installed a couple extra small cleats I use to tidy up the line).3. Most of the time I reef before splashing and, if the wind subsides, I shake it out. I have as yet to have to reef while out on the water so I don't know how convenient it will be. I had some concerns about the hooks shaking out but this does not appear to be an issue.Other: I am considering moving the reefing sheave (is this technically called a "cheek block"?)on the end of the boom more forward. I'm thinking I might be able to get a flatter sail shape this way???
