Wind Loads on Sail
It's interesting that some of the new sails come only with webbing. My sails came with D-rings for reef points and O-rings on the head and tack of the jib, but when it came time to replace the sails I asked the sailmaker to just use webbing. Also, I'd like to put a plug in for reefing early to protect the sails. The original sails on our '88 H-35 were replaced in '98 due to excessive draft at a cost of over $5K. This wouldn't have been necessary if I would have reefed earlier. When the sails were new we often sailed with a full main in the low 20 apparent and it wasn't too difficult. As the years went on the draft of the main and the jib gradually increased and the heel angle also increased in the same wind strength. Eventually the first reef started to be put in increasingly earlier, 18 knots, 15 knots, and sometimes even as low as 12 knots apparent (going to weather). OEM (Original Equipment Manufacturer) sails are not necessarily made of the best fabrics as suppliers are selected probably on a low bid basis, consequently one gets whatever is the minimum. When the sails were removed for winter storage they were taken to one of the local lofts for repair, not the same one every time, and the sailmaker often commented on how stretchy the fabric was. My new sails are made with the next weight heavier cloth, they are heavier, more difficult to flake, take more strenth to hoist, but have a beautiful shape, and hopefully will be the last set of sails I'll have to buy.
