K
kevin
I seem to have trouble getting the reefing tack reefing cringle down to the boom on my Oday 23. The pin (sail stop)at the top of the sail slot prevents the tack from getting low enough on the mast. Loosening the downhaul to raise the boom doesn't seem like a good solution either, since there is danger of the gooseneck coming out of the sail slot. The only solution I have found is to remove the sail stop before I ease the main halyard, which allows the tack to be drawn down neatly next to the boom. However, this is an extra step and it seems like there should be a better way.
