reefing
Bion, I need a little more information from you before I can tell you what you need.Is there a hook on the boom near the gooseneck? Are there blocks along the boom that correspond to the grommets in the sail?Basically, you most likely have one of two systems. In the first, a line runs from the boom, through the aft-grommet, and through a block that turns it forward along the boom. Pulling this line pulls the clew of the reefed sail to the boom. With this system, there is a hook forward to hold the leach grommet.In the other case, the forward hook is replaced by another block, and the line runs through it up through the second grommet, and then either to the boom, or through more blocks to the cockpit.Either of these make sense to you?Justin - O'day Owners' Web
