Yes, It's a potential problem.
With the main properly reefed, the boom should be at the same point as it was before you reefed it (or possibly slightly higher).The most likely cause of this is that you either used the flattening reef point as your clew reef, or you didn't attach the reef lines properly. (The line should run from the end of the boom through the reef cringle and then tie to the boom DIRECTLY BELOW OR SLIGHTLY AFT of the reef cringle.) That method of attachment both pulls the sail down to the boom and provides adequate out-haul to flatten the sail.If you are using single line reefing, it is important to tighten the reef line as much as possible to bring both the tack and the clew down to the boom (this also provents you from getting boomed during tacks). This also means that your reef attachment point should be properly located (on my previous C-30, the reef line was external to the boom and the cheek block at the aft end of the boom was adjustable. I just ran the reef line through the cheek block, through the cringle, back under the boom, and tied it off to a becket on teh cheek block.)No. Your boom SHOULDN'T sag when you reef it.SteveAlchemist C-30T #4764Alchemist C-320 #909
