Reduction Ratio
Tony Wilcox
Kevin Thanks for your reply to my question on prop recomendation for my boat. I checked with Hunter and they said the ratio is 2.83:1 Is this the ratio you based your recomendation on ? Tony Wilcox
K
Kevin
prop
Hello Tony: The recommended three blade is working out to be a 17” diameter x 14” pitch three blade. Hope this helps you out. Sincerely, Kevin L. Woody
