I am adding a chart plotter to my Hunter 27. I intend to use the current thru hull speed sensor location for the chart plotters transducer. The question is that the current sensor has a hole diameter of 2", the hole diameter for chart plotters transducer is 1 1/4". What is the best or preferred way to make up the difference in hole size. The dead rise block that the transducer will be mounted to measures 2" x 8" so it will just barley cover the original hole. Would epoxying in a spacer made fiberglass or some sort of acrylic to act as a reducer bushing work. Would there be a need to bevel the sides of the bushing/hull before epoxying in.
Thanks for your help
Marty
Marty
