Redoing the spreaders on my H23 question.
132
- - pueblo, co
I am refurbishing, rewiring, redoing the mast on my H23 for the season....and seasons to come. looking at the way the spreaders mount to the tangs on the mast with a single #10 machine screw doesn't excite me. does anyone know why i can't redo this system with 2, 1/4" bolts through each spreader/tang? there's plenty of "meat" on the tang and and spreaders, and room to space the holes. i assume the spreaders need to be sweap quite equally as tension put on them by the shrouds would be uneven and possibly tend to twist the mast if i didn't get them the same. (maybe this is the reason for the single screw?) i'm assuming i could get them real close but how exact is exact enough? a little bit off at the tang/mast end could be an inch or two off at the end of the spreader tip.
