Red at night, sailors' delight ...
This old saw has some basis in science, and is a fairly good predictor of (though no guarantee of) weather at the mid latitudes, in the Northern Hemisphere. In these regions, weather systems generally travel from west to east (following the jet stream). A red sky in the morning indicates a sun rising in clear eastern skies, and casting its rays on storm clouds approaching from the west, hence an unfavourable day At night, the clear sight of the red setting sun would tell a sailor that no storms are to the west, hence a favourable day.Some Weather Rhymes:These rhymes summarize rather neatly, and in an easily remembered form, a number of rules for the amateur weather forecaster. Although there is a considerable degree of truth in them, these rhymes are not infallible and you should use them with caution. Long foretold, long last, Short notice, soon past, Quick rise after low, Sure sign of stronger blow. When the glass falls low, Prepare for a blow; When it slowly rises high, Lofty canvas you may fly. At sea with low and falling glass Soundly sleeps a careless ass, Only when it's high and rising Truly rests a careful wise one. Wind and Weather A red sky at night is a sailor's delight, A red sky in the morning is a sailorman's warning. The evening red and morning gray are sure signs of a fine day, But the evening gray and the morning red, Makes the sailor shake his head. Mackerel sky and mares' tails, make lofty ships carry low sails. When the wind shifts against the sun, Trust it not, for back it will run. When rain comes before the wind, Halyards, sheets and braces mind, But when wind comes before rain Soon you may make sail again. If clouds are gathering thick and fast, Keep sharp look out for sail and mast, But if they slowly onward crawl, Shoot your lines, nets and trawl. See also:“Weather Wisdom - Some Simple Rules of Thumb” at:http://cruisersforum.com/showthread.php?s=&threadid=1785and“Weather Information Links”http://cruisersforum.com/showthread.php?s=&threadid=1767SOME WEATHER OBSERVATIONS ~ and their ~ LIKELY MEANINGSBAROMETERWINDLIKELY WEATHER FORECAST>30.2SW ➛NW & SteadyFair, Small Temperature Change30.1 - 30.2SW ➛NW & SteadyFair 1-2 Days, Steady Temperature30.0 FallingNE ➛SE Rain in a few Days30.1 - 30.2 FallingNE ➛SEWind & Rain in 12 Hrs> 30.1 FallingNE ➛ESUMMER: Lt. Wind & Rain in 3 DaysWINTER: Snow & Low Temperatures< 29.8 Falling FastNEStorm Warning & Rain/Snow30.1 - 30.2 RisingSW ➛NWFair, but Rain in 48 Hours>30.1 Falling FastNE ➛ESUMMER: Rain in 1 DayWINTER: Rain or Snow in 12 Hours30.1 - 30.2 Falling FastSE ➛SWind & Rain in 12 Hours>30.2 FallingSW ➛NWFair for a few days, Rising TemperatureCLOUD TYPEAPPEARANCELIKELY FORECASTCirrusHigh, Whispy, WhiteWarm & FairStratusHigh, Grey, in Flat SheetsDrizzleCumulusPuffy, WhiteFair, but Watch Out if they DarkenAlto- StratusThickening, Darkening, Medium Alt’Possible RainAlto-CumulusCotton PuffsFair, but Possible StormStrato-CumulusTightly Layered Puffballs, Medium AltitudeChangeCumulo-NimbusDark, Tightly Packed BallsWorsening , Possible LightningCiro-Cumulo-NimbusPuffballs, Mackerel SkyFair, but ChangingNimbo-StratusHeavy, Low, Grey, ThickFog, Drizzle, RainCirro-StratusHigh Sheets or Grey Haze, Solar/Lunar HaloFair, but Possible RainOOPS - sorry it didn't format properly.It's a Weather Cheat Sheet Table.I could FAX it to anyone who wants one.FWIW,Gord May
