Bad thing! Bad thing!
You've got the dock end plugged in backwards. Or worse, you have a short. In either case, your breakers will not operate correctly and power may still be live even if you switch the breakers off. This may cause fire or shock due to your short, etc. Leave unplugged until problem is diagnosed and solved.
