use halyards as a temp support, and only disconnect and service one shroud at a time. Cap shroud will be fine gone with temp support, forward and lower in the mix.
edit: i misread, this is core, not bedding replacement: best to pull the mast if you can so you can attack the whole area. Otherwise temp support is still recommended.
