Hunter 40.5 40 gal fuel tank
I would like to install a fuel polishing system that I can use periodically.
I have had a separate pickup tube and return tube built into my new tank. I already have the filter but will need to get a suitable pump. Anyone have any suggestions for volume flow rate (gal/hr) and max or min output pressure. The filter will be on the suction side of the pump with a gauge on the filter.
Any suggestions on the pump would be appreciated. I'm considering having it wired so it runs whenever the engine is running - is that a good idea or just a switch to run it periodically.
Thanks in advance
Thanks in advance
